new cpu ?
Discussion in 'Computer Components' started by derby4life, Sep 16, 2007.
  1. derby4life
    derby4life
    Aug 23, 2004
    230
    +10
    hi guy's ...is it much of a job replacing my cpu... its probaly 5 years ish old now emachines 380 2.20 ghz
    any ideas can I replace it no worries ...and how much £££'s
    just trying to upgrade my pc as I go
    cheers :thumbsup:
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    about the only bit you will be able to reuse is the Hard Disk.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,547
    Rainham Essex
    +2,523
    I would guess that as the PC is 5ish years old then you would probably need to replace the motherboard if upgrading the CPU as newer CPU's will almost certainly have a different pin layout. This would then probably mean new RAM and buying a new OS (OEM software is locked to motherboard (legally at least)). So you may find it easier (and cheaper?) to start from scratch.
    However you may find an old compatable CPU for your PC that offers a bit more speed which would make life easier.
    Mark.
  4. derby4life
    derby4life
    Aug 23, 2004
    230
    +10
    oh....that wasn't quite the answer I was hoping for :rolleyes:
    thanks for the reply though :thumbsup:
  5. Simba
    Simba
    Apr 11, 2006
    6,356
    Scotland
    +819
    maybe start off in thinking how much you have to spend and work from there
