New Computer With Vista
suzilamb
My XP computer is on it's last legs and i need a new one. My question is should i buy an Vista or XP on my new machine? I've heard a lot of bad news about Vista. Is it just lies?
Empwan
In the beginning Vista was poor, lots of incompatible problems with anti-virus and graphic card drivers.
This is now history. If you do a search for Vista, you will find a thread with people talking about if they would go back to XP from Vista. From what I've read +85% of people would never ever go to XP.
Make of that what you will.
ntm1275
The only time you may get a problem is if you build your own PC and use any old hardware like a sound card or Network Adapter
There may not be specific Vista drivers for these devices
If you buy a brand new PC with Vista already installed, or build a PC with current up to date hardware, Vista will work OK
TOM ALLEN
I've heard it can be very RAM hungry, is this true?
Cheers:smashin:
namuk
do not worry sp1 fixed massive problems (well most 64bit) i have just gone 64 bit i was 32bit for months and i got a epson 1200 scaner working under 32bit vista (with xp driver forced) and that scanner was 10 years old:smashin:
namuk
Cheers:smashin:
i would recommend 2 gb min (ideal 4gb). it is because it is a newer operating system + there is more running in background
matched 4gb mem not that dear now
off topic mate i sorted ariel :thumbsup: got a B+Q one they messed price it should of been £70 got it for £16 with kit and leads :smashin:
