New Cinema Room
Discussion in 'Members DIY Home Cinema Showcases' started by Gazza, Feb 13, 2005.
  1. Gazza
    Gazza
    Thought i would Share my pics with you all
      Size:
      87.3 KB
      212
      Size:
      42.1 KB
      185
      Size:
      22.4 KB
      173
      Size:
      28.8 KB
      220
      Size:
      25.1 KB
      234
      Size:
      33.5 KB
      249
      Size:
      37.9 KB
      268
      Size:
      36.4 KB
      268
      Size:
      31.8 KB
      325
  2. Gazza
    Gazza
    Took Weeks to do, still a bit of tinkering will add more pics later
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  4. Gazza
    Gazza
    Cinema room :- Philips LCD 30PF9975, Denon DHT 500SD, Nokia Freeview, with a Stand from Littlewoods ! check out link http://www.littlewoods-online.com/r...roduct=82423704 (Good Quality for £45)
  5. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    What speakers are those?
  6. Gazza
    Gazza
    Came with the Denon DHT 500SD package
  7. fraser h
    fraser h
    Mar 14, 2005
    i like what you've done with mounting the tv. can i ask you a few questions.
    1. is the tv bracket attached to the brickwork behind the plasterboard so the tv sits flush with the plasterboard?
    2.is all your cabling passed down between the brickwork and out through the skirting board?
    3.how easy is it to get at the cabling for trouble shooting and if cables need upgrading?
    I'm in the process of doing my garage and your's looks just how i imagine my set up.Sorry for being so nosey!
  8. Gazza
    Gazza
    1. Yes the TV bracket is fitted to the brickwork and the TV is slightly proud of the plaster approx 30mm.
    2. The Cabling is passed between the brickwork and plaster (Gap of approx 90mm for false wall and the cables come out directly behind the DVD / free view box via two electrical sockets that have blanking plates on to hide opening.
  9. Gazza
    Gazza
    3. Have not really gone that far but I would say it would only take minutes rather than hours. Still better than having them trailing all over the place.
    P.s You are not being nosey glad to help fellow Cinema room enthusiasts
