New Chyangfun Case
Discussion in 'Desktop & Laptop Computers Forum' started by Oblivion, Mar 18, 2003.
  1. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
  2. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    www.scan.co.uk have these, including the new P4 based motherboard & case for a reasonable price (£200 ish I think)
    I think they look great!
    There have been a few reviews of this case < here >
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,493
    Birmingham
    +205
    I have this case, with my choice of motherboard (PIII). Off the shelf it is quite noisy. The PSU requires a fan mod that replaces the stock item with a quiet one (40mm), and the main case cooling is a crossflow fan that is noisy even when slowed to sub 2000 rpm speeds. 2 40mm fans can be used in its place and combined with the reduced heat of my tualatin cpu, should leave me with a quiet pc. On the plus side the case looks stunning, downside is the expansion slot is half height. This was resolved by the aquisition of an ATI Radeon 7500 PCI that is half height and uses the DVI output only. Case only can be aquired from Kustompc's and I can personally vouch for their excellent customer service.
    A quiet alternative to the PIII/PIV boards are the Epia boards also sold by the above.
