New centre for JM Labs sib & cub ?
Discussion in 'Home Cinema Speakers' started by Andy1, Feb 24, 2005.
  1. Andy1
    Andy1
    Hi all - can anyone help ?
    I own the sib and cub connected to a Pioneer VSX 812. I am very happy with them, except I feel the centre is a little weak / lacks mid range. Indeed, I feel that speech is a little more "tinny" than speech direct from the TV.
    With this in mind, I wonder if anyone has thoughts on :
    Ø is this likely to be a function of the receiver - are there any tweaks that may help ie receiver adjustments, or would "expensive" speaker cable make a difference (using 35 strand supplied with kit by Creative Audio)
    Ø if it is the speaker that is lacking, can anyone recommend a suitable upgrade that would tonally match the other sibs (budget up to, say, £150 as I assume my set up could not do a more expensive centre justice). Ideally, not a monster size center as it has to sit on top of the TV and wife pressure may become a factor.
    Many thanks for any input
  2. arielshiran
    arielshiran
    would probably be a Sib XL or a Sib XXL speaker which will perfectly match your sib speakers and will for sure give you better center performance.
    Try it and tell us what you think.
