new center speaker
I
izzy01
can anyone tell me the difference between
ELAC Centre 1 CM
and
ELAC CINEMA 05 CENTER
both are listed on elac.com but I can only find CM1 in UK
here's the spec for both but it might as well be written in German for what it actuall ymeans to me. can anyone tell me in plain english what difference each speaker would make?
Specifications for 05 Center
(Specifications and design features are subject to change.)
Dimensions H × W × D 90 × 215 × 100 mm
Gross Volume 1.7 l
Weight 1.5 kg
Type 2-ways, closed, integr. high-pass filter
Woofer 2 × 80 mm cone, (mag. shielded)
Tweeter 1 × 19 mm ringdome, (mag. shielded)
Recom. Amplifier Power
at Nominal Impedance 20-150 W / channel
Crossover Frequency 3,800 Hz
Sensitivity 87 dB / 2.83 V / 1 m
Nominal Impedance
suitable for amplifiers (from ... to) 6 Ohm
4 ... 8 Ohm
Minimum Impedance 4.9 Ohm / 450 Hz
Frequency Range 100 ··· 21,000 Hz
Nominal / Peak Power Handling 50 / 70 W
Specifications for CM1
Dimensions H × W × D 90 × 215 × 103 mm
Gross Volume 1.7 l
Weight 1.6 kg
Type 2½-ways, closed, integr. high-pass filter
Crossover Frequency 1,300 / 3,800 Hz
Nominal Impedance
4 ... 8 Ohm
Minimum Impedance 4.6 Ohm / 500 Hz
Frequency Range 95 ··· 21,000 Hz
Nominal / Peak Power Handling 55 / 75 W
many thanks
