New Case Arrives Today: Strata
Discussion in 'Desktop & Laptop Computers Forum' started by phcjpp, Dec 17, 2003.
  1. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    Hi All,
    Just thought I would start this off:
    One of these is arriving today...
    http://www.standsunique.com/strata.html
    I will post photos as I build it. Its gonning to be used as a dvd / music player getting content from a raid 5 media server (already up and running and serving music and dvds)
    Spec roughly p4 3.0 with radeon 9800 pro graphics. RME Digipad sound card and gigabit ethernet on a micro atx motherboard. Full size silent 400 watt PSU.
    Let me know quickly if the spec needs adjusting as I am about to order the bits.
    Chris
  2. Mr THX
    Mr THX
    Nov 26, 2002
    1,293
    Barnsley
    +31
    Case does look stunning, in both black and silver - look forward to those pictures.
  3. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    Ok this is from the front. The build quality is abs fantastic. Very solid indeed.
      Size:
      21.1 KB
      260
  4. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    At inside
      Size:
      20.8 KB
      260
  5. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Nice to see some ventilation under the processor and the area around the MB. Sure is a pretty case.
    Your specs look fine, what mobo are you intending to use?
    Have you thought about a PSU, I recently changed mine to a seisonic with 120mm fan which is the best I've "not" heard.
  6. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    Thats exactly the one I was thinking of getting (PSU). As for motherboard a micro-atx from Intel with gigabit lan £99 from dabs.
    By the way the case is £220 + vat.
    Chris
  7. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
  8. fred123go
    fred123go
    Sep 16, 2003
    1,040
    39
    Cobham, Surrey
    that case looks great, i am kind of getting into HCPC's and that looks just the job for it. As it is more compact what kind of components can you fit in there?is it just the normal motherboards, graphics cards etc?
    fred
    sorry i haven't got a clue about pcs!
  9. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    It takes a micro-atx motherboard - I bought an intel one from DABS for 99 quid - does the job nicely and don't let the micro fool you - it will run all the Intel Processors with the fastest available specs (3.0GHz + 800MHz FSB PC3200 ram)
    Chris
  10. Jenz
    Jenz
    I have used a variety of uATX MB's in these units for various people with no issues. I personally have found the Intel boards to be really nice for this case due to the positioning of components on the board itself.
    The only warning to note (and it's fairly standard for this type of case) is that if you intend to use a full length PCI card which also features a molex power adapter then the smallest case is a tight fit for this card style. Note it DOES fit but due care and attention needs to be made. If you are likely to use a number of full length cards then the slightly deeper model will make a huge difference to you.
    Regards Neil.
  11. X-Factor
    X-Factor
    Nov 1, 2003
    57
    Scotland
    Looks nice, take it there's no room to fit a lcd doodah in behind the glass bit??
  12. phcjpp
    phcjpp
    Jan 29, 2002
    71
    London
    If you did away with the dvd yes :)
    Chris
