New car battery improves performance ?
Discussion in 'Motoring' started by PiperCub, Mar 19, 2017.
  1. PiperCub
    PiperCub
    Nov 11, 2016
    1,195
    87
    Sussex
    +278
    I've a 2011 1.25 fiesta zetec. The battery went dead and the aa changed it for another 2 days ago.
    When I've been driving it in the last few days it seems much more responsive to throttle and just drives better and accelerates faster. The old battery was tested and was way down in current. So could this affect the current to spark plugs and thus, that's how performance has been affected.
  2. PSM1
    PSM1
    Dec 20, 2008
    26,279
    +5,432
    Once running it is the alternator that provides the current to run the car and has extra to charge the battery so I doubt it has made a difference.
  3. supergeeman
    supergeeman
    Oct 4, 2016
    32
    GB
    +15
    It maybe that you have reset the ecu, maybe had an old fault code that was cleared by removing the battery
  4. outoftheknow
    outoftheknow
    Nov 1, 2012
    3,849
    Canberra, Australia
    +1,387
    They did check the alternator output as well?
  5. Wardy257
    Wardy257
    Dec 28, 2013
    1,382
    116
    +775
    Your alternator is probably doing less work now which may give a small increase in power. As others have said it may just have cleared the adaptive strategy memory in the ECU so it's learning again.
  6. IronGiant
    IronGiant
    Jun 7, 2003
    65,475
    +45,286
    The OP is no longer a member here :smashin:
  7. Wardy257
    Wardy257
    Dec 28, 2013
    1,382
    116
    +775
    Is it something you said?
  8. IronGiant
    IronGiant
    Jun 7, 2003
    65,475
    +45,286
    Not me, honest :D In essence, he went into meltdown over expensive cables and told Stuart what a rubbish site we have :laugh:
