New bulb for HS10
Discussion in 'Projectors, Screens & Video Processors' started by robfitzp, Aug 8, 2004.
  1. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Can anyone recommend a cheap supplier of a new bulb for a HS10?
    Rob
  2. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    www.pricejapan.com
    AFAIK about €300 including the VAT you may get cought for (I didn't) when importing from outside the EU
  3. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Cheers - I assume it is the same lamp for UK HS10s and imports?
    Rob
  4. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Yep, the part is "LMP-H180" which is now also the lamp for the HS20 and is (according to something I read on AVSFORUM) much improved on the older HS10 lamps
    Conor
  5. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Thanks Comer
    How many hours have you had on each bulb?
    Currently on 1600 on my first.
    Rob
  6. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    I think I killed the first lamp by turning it on straight after it had shut down in a powercut. It had about 300 hours (replaced by pricejapan under the projector warranty). The second lamp had the lamp bug so I returned that one within the 90 day lamp warranty period and the last lamp is running flawlessly (knock on wood) and the projector is now at 900 hours.
    I would not complain if I got 1500 hours from a lamp. This would represent about two years viewing for me and at €150 a year that's not bad. My bin charges are twice that :eek:
    Conor
