New build
allspark
Hi, I was wondering if all of these parts will be compatible. I'm building without graphics and buying a card about a month later, I already have cd drive and wireless card, any help appreciated.:)
processor- Intel i5 2500k
mobo -Msi z68A-GD55
case- fractal design r3
psu- 650w antec truepower modular
ram- 8GB corsair xms3
ocz ssd
cooler ?
LJx
They are all compatible, I would shop around for a deal on a HDD though
allspark
Thanks:smashin:
I'll have a look around for hdd, hopefully they'll come down in price next year and i can get a bigger one. thanks for you'r help.
llama
I would go with 8GB RAM personally, it is not a lot more money, and it will make your system more future proof, if that is even possible with computers ;)
allspark
Thanks I'm changing it to 8gb its worth it:smashin:
shadowboxer
Completely agree that now is the time to snap up 8GB or RAM as it's so cheap even though you don't need unless your encoding/photoshop etc.
The Corsair builder series PSU's aren't great. The Antec one you spec'd above is very good and modular. Remember though the fractal design define R3 hasn't got a windowed case (although they are rumoured to be releasing one next year) so modular isn't all that essential but it does improve case airflow and is easier to build with.
With current HDD prices still high (but slowly falling), rather than getting a £56 250GB HDD I'd grab an OCZ Agility 3 60GB for £70 and install your OS and vital programmes/game or two to that. Then when prices have stabilised and back to normal grab a storage drive or keep and eye out on the classifieds if budget is tight and one is need urgently.
Motherboard is fine but I'd go for this one. Bit cheaper and overclocks brilliantly!
MSI Z68A-GD55 (B3) Motherboard
What CPU cooler are you using? Surely not the stock Intel one?
allspark
I'll have a look at them thanks.
Thanks again I've changed to that one.
Yeah I was going to get a hyper 212 or a Gelid later on as I didn't know if there would be much point overclocking since I wasnt going to be gaming on it for a month until I get a graphics card. Do you think its best getting one straight away?
shadowboxer
I would just get a cooler now. It'll save you a right pain in the backside if you have to remove the motherboard to fit the new cooer. (Although the motherboad tray on the Fractal Design Define R3 has a large cut away behind it). For the sake of £25 (+P&P) I'd rather get it now.
John7
Well, seeing how the 2500k is easily capable of 4.5gHz out of the box with no voltage tweaks (just crank up the CPU multiplier to 45), probably worth getting a better cooler!
shadowboxer
Perfect.
allspark
Cool:) one last question will that psu be enough for a 2gb 560ti ?
shadowboxer
allspark
Will take a look at them and thanks you've been a great help.
rubbertatti
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
