Hi all,
I'm in the process of starting a outbuilding home cinema build very soon and decided to apply for planning permission to allow for building height of 3.2M, due to the 2.5M max height PD rule (and decided on a warm roof constrcution). Dimensions of the build started out at 6.2M L x 4.2M D x 3.2M H (with a small 1.2M D x 2.2M W entrance porch offset to one side) . During the consulation phase, the planning office came back to me asking if I would be willing to reduce the depth of the build to 4M. I agreed to this in principal but having thought a bit more about it I'm not sure this is the way to go because internally I will probably end up with around a 3.6M wide room (only 20cm difference but it all counts). Although I only plan to put in a screen size of 3.2M max ( for now), I always felt I would like a wider room to give more space for 3 seats plus plenty more to move around and not have the side speakers so close, ideally finished around 4.5M approx.
My garden is on a slope and the fall to the planned location is approx 420mm, which with planning approved would give me an internal height once done of around just over 3M which is nice. However, if I just stuck to PD, I could go for 6.2M X 5M (or thereabouts) and end up with less than 30SQM internally which is ok for PD but my internally ceiling height would come down to approx 2.3M.
Wondering what everyone thought and advise would be in this situation but I guess the answer would be what's more important to me I guess...
Many thanks.
Many thanks.
