richardrj
- Joined
- May 3, 2006
- Messages
- 9
- Reaction score
- 0
- Points
- 4
I have a Panasonic DMR-E55 DVD recorder - my problem is that I can't get it to read new blank DVD-RAM discs. I have some old ones which I can still use successfully but whenever I try and put a new one in the recorder it says I need to format the disc using Disc Management. When I go to Disc Management and attempt to format this disc it says "unable to format this disc - this disc is not recordable", which is obviously not true.
I don't know if this is relevant but it has only started doing this since I moved to Austria (I bought the recorder in the UK). Is it possible that the fact I am using it in a new country is causing the problem? Or is it just a faulty recorder? I have tried both Panasonic and TDK discs with the same problem (some bought in the UK and some in Austria).
Hope someone can help, many thanks
