New bedroom TV (24" - 26")
Discussion in 'What Is The Best TV For You?' started by mrdogcat, Aug 25, 2013.
  1. mrdogcat
    mrdogcat
    Aug 18, 2006
    149
    +3
    Hi, I'm after a new TV for the bedroom.
    Between 24" and 26" (26" is the absolute maximum so ideally 24" unless a recommended 26" model is far superior).
    Would also like the TV to have DLNA so I can stream video from my media hub through my home network.
    Not got a budget in mind as TVs at this size are pretty reasonable and would want to buy the best one that's currently on the market.
    Thanks for all your help.
    Steve
  2. mrdogcat
    mrdogcat
    Aug 18, 2006
    149
    +3
  3. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  4. mrdogcat
    mrdogcat
    Aug 18, 2006
    149
    +3
    Thanks for your reply vickster.
    Yeah that one is in my short list along with the Panasonic VIERA TXL24X6B
    The pros and cons to them both are:
    Sony PROS - TV design and colour; would prefer a white TV so it doesn't sand out too much.
    Sony CONS - Sound is apparently quite tinny.
    Panny PROS - no real pros come to mind that the Sony doesn't do just as we'll.
    Panny CONS - TV design and colour... Just looks a little dull
    So after comparing they're quite evenly matched... The Sony has a serious con but the panny has no real pros over the Sony... So just need someone to recommend a better one or one over the other.
  5. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    I'd go to John Lewis and check them out. All small tabs will have weak sound, especially the slimmer ones. How loud does it really need to be in a bedroom?
