New Bedroom Build
steve12
Established Member
I have decided that the bedroom needs a new face lift , in fact it needed ripping out and starting again so that's what i have done. At first i thought i would put 5.1 surround sound speakers on the wall, but decided to just install 3 front speakers with the option to use 2 rears later on if needed. Most of the of the movies and tv series are watched downstairs via the HTPC. Anyway hope you like what i've done and hope to get everything posted in the next couple of days,
Steve
steve12
Established Member
This is how the bedroom was at the start i have removed the built in wardrobe doors and as you can see the wardrobes were very tired to say the least Sky HD had been installed at this point and hooked up to a nice portable tv :rolleyes:
at least it was something to watch whilst i was working :smashin:
steve12
Established Member
Started to dismantle the wardrobes couldn't believe the length of some of the screws and in some places even nails :confused:
As per usual some of the plaster came off so i decided to get the whole room skimmed over. An expense i thought i may get away without spending but if your gonna do something you may as well do it right...or so am told.
J-a-m-e-s_7
Established Member
Lookin gd steve can't wait to see the end results!:smashin: Love seeing bedroom setups and am in the process of doing mine, just delayed by work. I like to see you've got your priorities straight..SKY HD first to go in, cnt be working with no motivation haha :D
steve12
Established Member
Next stage was stripping the walls and getting rid of the old carpet wasn't to hard just a bit of a ball ache, also had to remove the back piece of skirting board so that the media units could sit flush to the back of the wall, needed to use the crowbar to get the skirting off and as you can imagine the lower part of the wall decided to come with it so getting it skimmed was a good idea :smashin:
steve12
Established Member
Thanks James,
Yeah your right mate can't beat a bit of Clubland TV and Kerrang whilst stripping the walls. :thumbsup:
steve12
Established Member
Plastering is all done, decided not to plaster the wall where the built in wardrobes had been as there was going to be new built in wardrobes installed. or thats what i told everyone..The real reason was due to my slight miss-calculation of how long it takes for plaster to dry i would of been putting wardrobes on to damp plaster which wouldn't be the best idea in the world. There is a filler to go around the wardrobes so it all worked out in the end.
steve12
Established Member
Hi mate,
TV is 42 Panny along with Amp, Sky HD And Xbox 360 Elite.
Will post some more pics either later tonight or tomorrow mate.
Cheers,
Steve
steve12
Established Member
Wardrobe's insides are being installed and then plaster left to fully dry out. Electrician has been and installed the spotlights and additional electrics and a couple of coats of white emulsion has been applied. Built in chest of drawers and media unit has been put into place. a few paint testers applied to see which colour to paint the false wall.
Cheers,
Steve
steve12
Established Member
Does anyone know how i change my title to
New Bedroom Build With False/Floating Wall
Cheers,
Steve
J-a-m-e-s_7
Established Member
Really coming along now, where did you get your wardrobes and chest of drawers from? Won't be long before all your av gears in :thumbsup:
steve12
Established Member
Cheers lukeyy,
James the chest of drawers are called Zebrano they have a slight gloss finish to them, they match the wardrobes also had a couple of single black gloss wardrobes on either end.Also used the black gloss when doing the top and bottom plinths to frame the zebrano wardrobes, a friend in derby made them he makes kitchen and bedroom units, you should be able to find the zebrano using Google
steve12
Established Member
All finished now, radiator has been put on, new carpet installed, media unit glass door installed.
False wall has been installed and framed along the top in black gloss, Socket fronts pushed on, the speakers will be replaced with black ones once funds allow.
There is cable run along the back in case i want to use 5 speakers but 3 are fine for me as i watch most TV and Sky downstairs.
Kit Used is
42" Panasonic PZ70B
Denon 3802 Reciever
Xbox 360 Elite
Sky HD
Kef Speakers
Thanks for looking
Steve
lockdown81
Established Member
oh no lol , looks the nutz mate well done , ive only just got the first coat of paint on mine last night lol , best i get a move on i think :thumbsup: how long it take you start to finish ?
steve12
Established Member
Thanks for the kind words everyone
From start to finish mate think it was about 3 weeks but that wasn't doing something everyday.
Steve
beecee
tidy set up you have :smashin:
steve12
Established Member
Thanks beecee
:smashin:
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
