New AV Receiver required
Discussion in 'AV Receivers & Amplifiers' started by Cwhelan, Jan 29, 2005.
  1. Cwhelan
    Cwhelan
    Jan 29, 2005
    141
    16
    Milton Keynes
    Hi All,
    I have just installed my new Plasma Pioneer PDP505XDE (very nice indeed :) ) & complimented the look with B&W FPM5 Front L,R & C with a pair of M&K's at the rear. However I have just discovered that my AMP is on it's way out!
    I currently have a HK AVI 250, which has been good over the years expecially with it's supporting ADP 303 doing the decoding.
    I was looking at the Denon 3805, does anyone have any views? or other suggestions? my budget is around £1k :lease:
    Cheers,
    CW.
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,516
    London
    +1,005
    For £1k I'd also consider the Pioneer AX5Ai, Marantz 8500, Arcam AVR-250 and Yamaha 2500. Whichever one you choose will depend on your preference to home cinema or music.
    Try and shortlist a few and demo them if you can, makes a big difference.
  3. Cwhelan
    Cwhelan
    Jan 29, 2005
    141
    16
    Milton Keynes
    Thanks will have to get a few to Demo. I'm looking more for Home Cinema.
