Hello everyone,
Been searching the forums here for a few weeks trying to solve my dilemma. My HT setup is approx 10-11 years old. I'm running an Arcam AVR 280 with B&W 602 fronts, LCR 60 centre and 550 in walls for surrounds in a 5.1 set up. My sources include apple TV 4K, Xbox series S, Nintendo Wii (yes a Wii), Oppo BDP 83 (via Multi channel analogue outputs), Cambridge 640C CD player, IFI Zen DAC for streaming hi res music. My outputs are to a 1080P Epson 6100UB projector and a 22" Toshiba (720p) which sits over the bar at the back of the room.
As the apple TV 4K is only HDMI out and did not have an optical out to run to the Arcam I picked up an audio extractor off amazon and it worked fine for awhile. It recently went all wonky in terms of its colour. I've tried different cables etc. When I remove the extractor from the chain the picture on the projector is fine but that leaves me with no sound. The simple solution would be to get another extractor and be done with it however I don't want to have to keep replacing it at $30 to $50 a pop so I started looking at different work arounds for the apple TV. The first was to pick up a higher end oppo on the secondary market that has the HDMI in port and plug the apple tv into that then use the multi channel analogue outs into the arcam. The used market for the oppo's in canada is not cheap. The lowest I could find was a 103 advertised for $550. This got me thinking about maybe it's time to finally move on from the ARCAM (which frankly I still enjoy).
I began looking for AVR's - the current crop of Arcam's are to expensive for me now even older models. I have been looking at Denon and Marantz. Denon 960, 1700, 2600, 2700. Marantz 5015 and Anthem 520, 540.
There are so many bells and whistles these days it's hard to keep track and with my current block of equipment I can't even take advantage of some them. While I won't be upgrading to a 4K projector any time in the immediate future I may down the road so should I future proof? Do I really need a 7 channel analogue input or would I be happy with simply the HDMI from the Oppo. If I spend a significant amount of money $1500-2000 should I ensure it has pre outs so I can just add an external amp in the future.
In reading some of the other AVR threads I've picked some great info regarding multiple HDMI out downgrading to the lowest resolution for output. I do want to have both devices hooked up so a dual HDMI output is important. I can probably pick up a used one that will suit my current set up..but what is that exactly?
Would really appreciate some suggestions from those with a far greater understanding of all the new formats/codecs etc.
cates
cates
