Quantcast
New Arcam AVR's
goskiingmn
Been watching this thread constantly and set it as a page to launch when I start my browser.
Just figured out that if you set the page in the URL well beyond the page we are on it will always open to the newest page.
Changed page to 200 and it brings you to here which is currently 46.
www.avforums.com/threads/new-arcam-avrs.2248063/page-200
Can't wait to get Dirac going again, been a long few months without it!
tviviano
Question, the mic supplied by arcam in the box, do I need a calibration file for it??
The Arcam Mic and Target Files on the ARCAM download page has calibration files for both the old and new usb mics and a quickstart file for Dirac explaining which to use.
fatboy frank
I’ve just used dirac for the first time....has anyone else found the subs are way to loud. They are about 10db to loud according to REW
That's really interesting as most users with the previous version of Dirac generally report the bass as being a bit light!
So do you find the Sub's to loud, or is that just what REW reports?
mitch1922
D
i found it to bass heavy...then I used rew to check
fatboy frank
D
For Movies or music listening?
Remember that Movies and Music will often require different levels hence the Sub Stereo adjustment!
goatlips
D
Mine is very light on bass so light its non existent! Look at my graph how much it has pulled out and made my midrange stronger.
fatboy frank
mitch1922
Both music and movies it was awful
mitch1922
goatlips
SVS PB2000 PRO.
fatboy frank
fatboy frank
@mitch1922 out of interest, how have you got your sub's connected and what have you got your crossover set to?
mitch1922
494930
Are you accounting for the fact that the LFE channel is supposed to be 10db louder?
goskiingmn
Anyone else use subs like my REL that want you to draw of the front mains and the LFE? Need to figure out how to tune Dirac with that. I think you just disconnect from the fronts when doing dirac.
mitch1922
Yes I understand that 10db is added to LFE soundtrack
I checked it with rew and with an spl meter and it was way off
fatboy frank
So had you level matched your Sub's prior to running Dirac?
So how did you check it after you'd run Dirac, not using the internal test tones i hope?
fatboy frank
Unless it's been implemented differently on the HDA series, the internal test tones are independent of Dirac, to confirm levels post Dirac, you need to use an external source/calibration tones.
Similar threads
Trending threads
Latest News
BenQ launches new Home Cinema and Gaming projectors
  • By Andy Bassett
  • Published
Acorn TV streaming service to launch in UK
  • By Andy Bassett
  • Published
LG UK 2020 TV rollout and prices revealed
  • By Andy Bassett
  • Published
TV shipment forecasts slashed for Q2 2020
  • By Andy Bassett
  • Published
Samsung Display to quit LCD production
  • By Andy Bassett
  • Published
