goatlips
Just watched 1917..it sounded outstanding
On BD??
YesOn BD??
Just watched Xmen Dark Phoenix OMG blew me away.Just watched 1917..it sounded outstanding
The BD bundled with the 4K also has Atmos sound.On BD??
I’ll check that outJust watched Xmen Dark Phoenix OMG blew me away.
Bench Tests
When the space shuttle launches near the start of the film, my fillings fell outI’ll check that out
Just ordered it. Other half is back to work... praise the Lord. Can crank it right upWhen the space shuttle launches near the start of the film, my fillings fell out
If you look at perfect pursuits video he has the microphone horizontal 0 degrees. I guess that's why there is 2 separate calibration files.
I have tried both and the horizontal ie facing the 2 speakers works best for stereo in my room, but I use the 90 degree (vertical) for full surround speaker set up.
No thanks to you, I have learned a lot from your videos and reviews.I dont think the results are grossly different either way but I have reverted to using 90 degrees all the tim because if nothing else it makes it easier to position the mic where I want it, that is much harder to do when its horizontal.
Thanks for watching my video
+1 for thank-you for your video(s) on how to calibrate using Dirac, have been setting up the Arcam amplifier for music listening over the weekend following your video tutorial which has helped me better understand what to look for (very useful insights and explanation about what the aim of Dirac is and what to look for)!I dont think the results are grossly different either way but I have reverted to using 90 degrees all the tim because if nothing else it makes it easier to position the mic where I want it, that is much harder to do when its horizontal.
It's ok with tidal via airplay. Bloody thing!I do have the same issue with Spotify, and it seems to happen with other devices using google cast.
It's not an Arcam issue, this time
This was the same issue I had with 1 out of 3 samsung phones, but then it just started working one day and been perfect since.I've not streamed any spotify in a while because I use Roon and tidal. So when i stream spotify from your phone constantly drops its connection, will not even play a complete song??
Apparently they are a load of phone network problems today Three, O2 and another one so if it's just today its not working right, it could be this.It's ok with tidal via airplay. Bloody thing!
Exactly the same for me, level too low for sub (svs PB3000) which shakes the house,Me too i cant get my sub in the green without one of the rear back speakers clipping, without Dirac the speakers are all level at 75db with my Sound pressure meter and the Sub is very weighty.
and too high for rear speakers. Dirac complains of levels too low or high ambient noise so can't continue. Feel like selling it all!
I've always question to Dolby leveler even works.Dolby Volume and Dolby Leveler with height speakers
________________________________________
Hi All!
Can anyone with Arcam AVR10/20/30 test if Dolby Volume and Dolby Leveler works if height speakers are enabled? For example 5.1.2 with 2 front height speakers? Or in 5.1.4 configuration. Does it work with Dolby Atmos and DTS Master tracks?
Thank you in advance!
