New Amplifier decisions
Discussion in 'AV Receivers & Amplifiers' started by rjcowan, Feb 21, 2005.
  1. rjcowan
    rjcowan
    May 3, 2001
    211
    Comber
    +5
    Finally after having put my money together I have a budget for a new amp. Currently I am running a Yamaha 640 to drive B&W 602.5's at the front and 601's at the rear with the LCR60 for the center.
    I have about £600 and have been recommended the Harman 330. Any other suggestions to go look at?
  2. CosmicOne
    CosmicOne
    if u love the Yamaha sound,i recommend u look at the new RXV650/750 & if u are in the UK u will find DSP-AX750SE which (all of them)are very good & have great stereo sound in Pure Direct mode beside the famous Yamaha performance in movies.
    read the review of the 750 on this site,i think it's surpassed the HK330.
  3. Diamond
    Diamond
    Marantz 5500 (a bit warm) or Pioneer 1014 (more Yammy) are both winners in that class.
  4. rjcowan
    rjcowan
    May 3, 2001
    211
    Comber
    +5
    Thanks. I was just wondering if the change of Amp would make that big a difference. I am doing an upgrade and wondered would I really notice the difference if I added a bit more cash. What do you think?
    I find the yamaha great for sound but the 640 I have over half volume to get any volume out of it.
  5. recruit
    recruit
    The Harman Kardon amp will go nicely with the B&W Speakers good match and nice amp.
  6. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I'd throw in the Marantz SR7500 into the mix too, you should be able to negotiate a price closer to £600 with your dealer.
    The SR7500 is probably one of the leading amps under £800, the Pioneer 2014 would also be a good choice, but the Marantz is more musical. Personally, I've been quite dissappointed with the current HK range, their build looks flimsy not many features and the sound (although very good) has fallen behind some of the class leaders such as Pioneer, Marantz, Arcam, Yamaha and Denon, in fact, the HK models maybe the only range I would NOT reccommend with their current amps........hope this doesn't offend anyone, it is just my opinion :). Mind you, with your B&Ws hooked up to it, it could work quite well, as they are well suited to each other.
    When you get to the £600-£800 price bracket, you are almost guaranteed to get a cracking unit, most differ on house sound, so it depends on what you prefer, and what will suit your B&Ws.
  7. rjcowan
    rjcowan
    May 3, 2001
    211
    Comber
    +5
    Thanks for the guidance looks like i am out demo'ing again. alway hard with something like the amp
  8. markymark34
    markymark34
    Dec 15, 2002
    3,315
    Northern Ireland
    +337
    dont worry ill keep you right when we go for demo!
    like the time you wanted to spent £850 on speakers :thumbsup:
    lets make it a cool £1000 this time
    mark
