New amp??
Discussion in 'AV Receivers & Amplifiers' started by sharper, Aug 11, 2004.
  1. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    Currently got a Yami A5 and would like to upgrade to a better quality amp.
    contenders are
    Yami 1400
    Yami 2400 (what the benifit over 1400)
    Denon 3805 (is it worth extra an why) :lease:
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I would be biased as I would have to say Yamaha especially if you like the sound. If you can afford it get the 2400 over the 1400. It has more power and you can use the 7.1 setup with both the presence speakers at the same time for more effects. It has a good remote, the denon has had problems with the remotes. As the 1400 has been discontinueed you might be able to get a good deal on it at the moment.:D
  3. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    Please explain above?
    I will be using a Pronto so the romote is not an issue.
  4. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Why not the Denon 2805 also?
  5. morksbeanbag
    morksbeanbag
    Jul 25, 2004
    723
    Chesterfield, Derbyshire.
    +49
    yammys are decent for home cinema but suck at music. i had the RXV-800RDS for years and when i got my sony i was stunned by it musicality. I think hyperfi have some Sony ES models in stock at very good prices. Try the Sony STR-VA333ES, i think it was £299 down from £800. its got all the latest processing and 7 channels of amplification.
    Denon also would be a good choice. see if you can spot a 3803 cheap from somewhere.
    If you really want a yammy i'd suggest trying to hunt down one of there higher end but older models at a knockdown price.
  6. Radiohead
    Radiohead
    Dec 24, 2001
    4,396
    Amazingstoke
    +432
    That old (now untrue) chestnut.
    Try the RX-V2400/1400 or the new 750 amp to see just how they've improved.
  7. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    I'll vouch for that - my music sounds crisp, clear and extremely loud! :thumbsup:
  8. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    Ordered the v2400 from AV land (£689) yesterday and will migrate it across over the coming weeks let you know how i get on.
  9. ktng
    ktng
    May 9, 2004
    174
    16
    UK
    Yes I had a Yamaha RX-V795 and the RX-V1400 is just in a different class to it for music, so as others have said give the new Yamaha range a listen and you may be pleasantly suprised.
  10. HarshKarma
    HarshKarma
    Jun 28, 2004
    82
    9
    Ashford, Kent
    I was thinking of buying one of these as well but AVLand's website now has this as discontinued.
    Is there a new product coming?
    Ed
  11. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    there is always a new model coming! In this case I believe its 1500 and 2500 with added gadgets Iwould think. :thumbsup:
  12. HarshKarma
    HarshKarma
    Jun 28, 2004
    82
    9
    Ashford, Kent
    :rotfl: Soooo true!
    Hopefully the new one will allow you to use the prescence speakers in 7.1 mode. If so, I think I'll wait. :)
    Many thanks
    Ed
