New Amp New Speakers
Discussion in 'Home Cinema Speakers' started by enviromann, Jul 14, 2004.
  1. enviromann
    enviromann
    My insurers are replacing my old receiver with a Sony STRDB790 - I have decided to replace the old Sony speakers which were 'crap anyway' with a new speaker set up. Amy recommendations that will compliment the new amp/receiver would be gratefully received. :thumbsup:
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Sony STRDB790
    Good amp but bright sound.
    Carefully match needed, no bright speakers like B%W or even Monitor Audio...
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    How much do you want to spend? Can you accomodate floorstanders or are you after smaller compact speaker??
  4. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Mordaunt Short 904's or 912's depending on your budget. Quality floorstanders which are not that bright IMO (even though they have metal tweeters).
    If you can afford more, audition some Ruark & Tannoy floorstanders.
    DT
  5. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    MS's are quite bright and forward imo
    Mission M33/m3c2/M3ds/M3c1 combo with a MJ acoustics Pro 50 sub sounds like the best combo with the Sony amp to me
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I would advise other Mission models: Mission M33/m3c2/M30 + Rel Quake if Sub needed
  7. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I wouldn't advise Mordaunt Short Speakers with this amp, it has a reputation of being VERY bright, you need something to mellow them down like a set of Kef's or Missions.
  8. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
