New amp - Marantz 6010OSE Ki Sig
Discussion in 'AV Receivers & Amplifiers' started by NickXX, Jul 3, 2003.
Tags:
  1. NickXX
    NickXX
    I recently bought a pair of B&W 601s3s, and was hoping to replace my Marantz PM66se (which I bought in 1999).
    Richer sounds is doing the Marantz 6010OSE Ki-Sig model for £199.99, and I was thinking of getting it. Has anyone tried it out? I'm basically looking for somethign with a bit more weight, as I'm otherwise very happy with the PM66se.
    Thanks in advance,
    Nick
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    The KI Sig is a nice amp, but more "weight".....hmmm. I've always thought it was a bit bass-light compared with it's peers (NAD C370, Roksan Kandy MkI), but that is probably the Marantz family sound shining through. If you like the 66, the 6010 will surely please too. A definate step up from what you have IMO & £199 is a bargain!
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    If you Like the Marantz Sound the new PM7200 has been reviewed well it can be switched to 'Class A' operation £340 but you could shop around.
  4. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    I looked at buying into either of these amps for better stereo but am i right in thinking these will not integrate with my Marantz 5300?
    Would i be able to set the amps up together so i could use it with my AV amp?
  5. William Shin
    William Shin
    Nov 13, 2000
    58
    Wellingborough
    I went to RS with a friend of mine who wants to buy the Marantz 6010SE KI three weeks ago.
    I phoned the branch and checked the stock availability. The sales man said they got in stock so I reserved it.
    When we got there there wasn't any display of that model in the shop. The guy I spoke on the phone went to the warehouse to get the amp out. A few minutes later the guy came out with empty hands. Said to me when he tried to take it down from the rack something fell down on the box and damaged the one side of the amp. I could do nothing but laughing. What a silly lie! :mad:
    Instead he tried to sell their exclusive cheap cambridge audio amp. What a waste of time and petrol!
    Avoid RS and don't trust them! :thumbsdow
    But if they have got the amp on the shelf physically then go and get it. Good bargain.
  6. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    Rick.
    You want Both of the amps to integrate with your 5300? or either one of them?
    It is Quite easy to set a stereo amp up to run your front speakers while leaving your AV amp to drive the surrounds, there are many threads on the forum describing how.
  7. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    Hi, sorry i did'nt make it clear but what i think i am after is an stereo amp with a fixed gain?
    So then i can set the volume at 12 o'clock, use the pre outs from my sr5300 into the amp and then set the test tone levels up to match.
    Then hopefully i wont have to turn both volumes up at the same time.
    Does either the 6010 or pm7200 have these functions?
  8. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    You have two threads on this? Once you turn the volume dial to a specific position and leave it you have 'fixed the gain' all amplifiers are like this when you change volume you are changing the 'gain' of the amp, Leave the volume alone (at 12 o’clock if you like) and the gain is fixed.
    What I thought you were asking for in your other thread was an AV input, this is an input which bi-passes the volume control and has a true 'fixed gain' as I said I do not believe the Marantz amps have this functionality Arcam do as do a few other high end amp’s but if you ask me all amps should have this facility.
  9. Ricky27
    Ricky27
    Feb 8, 2002
    1,968
    Norwich
    +216
    No i dont have 2 threads on this, i only started one of my own because i wasnt getting any joy here.
    Your help is appreciated.
  10. NickXX
    NickXX
    Hi guys,
    Just an update, I decided to go for the Rotel RB03 which I got of JohnS on the forums. It's a 70w power amp, so hopefully will give the B&Ws the kick they need.
    Thanks for the help,
    Nick
  11. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    The RB03 is a power amp? How will you run it? Do you have a pre amp already?
  12. NickXX
    NickXX
    Yeah, I'm going to ditch my CD player and Tuner, and use my PC as my only source. I'm gonna use the M-Audio Revolution Soundcard as the pre-amp. If i'm really unimpressed with it, I'll have to spend a bit more on a pre-amp, but as it's the only source, I'm hoping it should be fine.
