New Amp for Home Cinema
Discussion in 'AV Receivers & Amplifiers' started by Sarge, Jun 26, 2002.
  1. Sarge
    Sarge
    May 30, 2002
    125
    +5
    a little advice please
    looking for an amp for a smallish room, will connecting ntlbox, video, dvd (digital output), xbox (digital output) and another games console.
    Been looking at the denon 1602- but i don't think it has enough digital inputs. Does the equivalent marantz (seems to have more inputs) match the denon.
    Secondly are there any slimline amps? I've seen the pioneer but it seems to be very limited on inputs.
    thanks for any advice
    I'll come back later for help with some small speakers :)
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,494
    United Kingdom
    +2,030
    The Denon 1802 may suit you better as it has 4 digital inputs, 3 optical and 1 coaxial. You´ll find as you go up the range the amount of inputs etc increases, this usually applies to most manufacturers.
    As you´ve mentioned, Pioneer have slimline amps but most others tend to be larger (taller).
    cheers
  3. Justin@UH
    [email protected]
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Marantz and Denon are usually very similar spec, you won`t get loads of digital inputs unless you go for a midrange amp / receiver. Exactly how many do you need, and what combination (.i.e optical / coaxial)?
    Panasonic have just released a slimline amp, sony are due onele, and yamaha are due one also late July. Pioneer are replaceing the current model next month, think it has an extra dig in....
    Hope that helps?
  4. Sarge
    Sarge
    May 30, 2002
    125
    +5
    Thanks I'll go take a look
    need two optical style ones, one for dvd and one for xbox
    now looking for some speakers - missions fs2av at empiredirect seem too good a deal at £370 coupled with yamaha amp or maybe aego p5??? ahh its all so confusing......
