New Amp Advice
Discussion in 'AV Receivers & Amplifiers' started by thfccambs, Dec 17, 2004.
  1. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    I'm looking to buy a new amp to go with my plasma or PJ.I have the mission FS1 speakers,changing the speakers is out of the question as cable all tucked under carpet and speakers wife friendly.
    I have seen the yamaha 2500 for about £700,would this amp be ok with the speaker system im using or are my speakers not good enough for a amp of this quality.
    What other amps should i be looking at?
    cheers. :D
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,822
    London
    +1,091
    The Yamaha 2500 is a brilliant amp, but if you are not planning on changing your speakers then a Yamaha 750 or 1400 would be more than up to the job :thumbsup:
  3. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    :thumbsup: Thanks for the advice,i've gone for the Yam 750. :clap:
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,822
    London
    +1,091
    Good choice, I'm sure you'll be happy with it!
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Hope so,just got to sort out the best way to connect it all now.Looking to use 575 dvd to amp by component and sky+ to amp then use both on component out to ae700.
    Hopefully will be way to get best picture from dvd player and sky+?
    Any other advice would be great.
    cheers
