Quantcast
New Amazon Fire TV confirmed as 4K UHD Player
Steve Withers
Reviewer
No it doesn't support HDR Steve.
Manni01
That's disappointing given that Amazon prime is one of the few sources of UHD HDR content in the UK. I guess we'll have to wait for a revision.
I already have the original stick for the living room TV and it's a great piece of kit (it cost me £15 as a pre-order with Prime!). I'll wait for the new version to support HDR before I get that one for the cinema room.
smackos
what is there to watch in 4K on it?
Basically right now there are a few Sony Pictures Catalogue titles you can buy in 4K from Amazon Instant (circa £18.99 generally) but in the main then it's the Original programs that Amazon and Netflix Produce so Daredevil, Bosch etc.
Will Parkinson
I'll be getting one for the simple fact that the sound from the built in Amazon player on my Samsung UHD TV is horrendously out of sync.
Sebastalona
Can these devices stream local content stored on a NAS?
MeanDorris
Manni, do you use Netflix on the Fire TV stick, if so have they fixed the stutter?
Stopped using mine and wouldn't go for the new one unless knew was OK....
Manni01
Thanks for the heads-up, no we don't use Netflix on the stick, only Amazon Prime and BBC iPlayer. Works great for those. My main interest in a UHD compatible one would be to stream HDR content from Amazon Prime.
Yappa
Didn't the old one have problems with 1080i playback (via Kodi)? Hope the new one rectifies that problem.
figrin_dan
What's the advantage over the built in TV apps?
My Panasonic tv converts Netflix DD+ to DD losing sync and locking out the lip sync option on my amp so I would consider it for that.
It's shown as having Plex, does that cover NAS files?
linnasak
Can you download 4k onto memory card then playback. Thinking of us poor souls who have slower broadband. Alternatively download less compressed versions.
Is 4k streamed much better than bluray when you take into account impact of heavy compression?
Kevin
BassPunk
No optical audio out..., it would be nice if it could output audio via USB
Cha1ky
Is the only addition really just 4K?
Recently got one of the current fire tv and have installed Kodi. Works a charm and was wondering if it's just 4k content. Don't have a 4k tv so won't feel to bad if it is. Won't be doing 4k until there's quite a bit of content.
jerryq7777
Trending threads
Latest News
Panasonic launches SC-HTB600 and SC-HTB400 soundbars
  • By Andy Bassett
  • Published
Panasonic launches HX940 and HX800 4K LCD TVs for 2020
  • By Andy Bassett
  • Published
Elipson launches 3230 loudspeaker at Bristol Hi-Fi Show
  • By Andy Bassett
  • Published
AVForums Podcast: 17th February 2020
  • By Phil Hinton
  • Published
