New All in One 5.1 system
Discussion in 'Home Cinema Buying & Building' started by MonkeyMofo, Jul 15, 2005.
  1. MonkeyMofo
    MonkeyMofo
    Hi there,
    I have a question regarding my new set-up at home.
    I have just moved house and have decided to get a Hitachi 32LD7200 LCD TV and wall mount it. Wife's uncle may be able to get me a discount from curry's. My question is that I am now looking for a system to run the audio through. I was thinking about getting the Samsung DVD-HD945 to play my DVD's and maybe music on occasionally (I have a smallish living room and don't want a separate hi-fi) My question is I am looking to spend about £300 (I know part of the TV is a wedding present, and the house is costing a fortune to do up!) on a av system to hook up to the sammy any pointers?
    Ahmed.
  2. MonkeyMofo
    MonkeyMofo
    Little bit more info maybe.
    I have been looking on the web and seen a Panasonic SC-HT05 av receiver and 5.1 system (~£200), this looks like it could be what I'm after. However in the future I would be tempted to go for a DVD-Recorder + Hard-drive. I have seen the Panasonic SCHT1500 for about £500 this has a 80Gb harddrive and a 5.1 speaker system, the only thing is I am unsure about connecting it to the TV as the reason that I was after the Samsung DVD-HD945 was that I could connect it to my TV via HDMI and the rave reviews it received.
    I am on a budget and I am looking for a set up that I can upgrade as and when finances allow.
    Ahmed
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You would be far better to look on Price Runner because they can probably beat anything that Curry's can offer, even with a discount.
    Re the surround sound system - two options -
    1. Buy a cheap "plastic" system like the DigiTheatre or the Yamaha TSS10.
    You will get tired of these very quickly, and want better, so,
    2. Save up your cash, and buy a decent amp and proper speakers and sub-woofer.
    I chose option 1. I should have gone for option 2 :)
  4. MonkeyMofo
    MonkeyMofo
    Price on the TV with the discount seems to be the same as anything on the net. Also by buying from currys/dixons I should be able to take it to the local store if any problems. Rather than posting it. On the separate front I am thinking that is the best option. however my wife wants to be able to listen to music in the living room. Catch-22 situation unfortuanley, don't really want to listen to music through the TV speakers. :(
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Sounds like your mate gets good discount from Curry's :)
    You don't have to listen to music through the TV speakers - just get an AV amplifer. Feed all your audio (Sky box, DVD, CD player,etc) through it. Many have outputs for two sets of speakers.
    Have a look at what Richer Sounds have to offer.
