New aerial for my house but so many to choose from!
Discussion in 'Freeview & YouView' started by leigh120585, Aug 28, 2013.
  1. leigh120585
    leigh120585
    Feb 12, 2008
    149
    shropshire
    +8
    Hi guys, i have just cancelled my sky subscription and have bought a Youview box. I did not notice that my new house has no aerial!:facepalm:
    My best transmitter is the Wrekin and i live near Oswestry (welsh border) If any one can point me in the right direction t would be great, thanks.
  2. Rich Marshall
    Rich Marshall
    Nov 14, 2006
    3,717
    Kirkby In Ashfield
    +585
    I'd point it towards Wrekin :D
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Very good! :laugh:
    Leigh,
    Have a look here:
    The Wrekin
  4. Rodders53
    Rodders53
    Dec 8, 2007
    5,129
    Bedford
    +918
    Prediction for SpecSavers in the Town suggest Sutton Coldfield would be better than The Wrekin from an interference point of view ... but your precise address may well differ and make The Wrekin the correct choice to tune to. Coverage Checker - Detailed View
    The two transmitters are not that far apart, bearing wise, and both may be picked up well with a single wideband or group K aerial aerial... DO also read the 'planning your installation' section of the ATV website which will help guide you through a d-i-y install.
    If you call in a professional check out the trusted trader section of your trading standards office - but a personal recommendation from a friend, work colleague or family menber, is always the best.
  5. blue max
    blue max
    Apr 12, 2006
    12,928
    London
    +4,299
    The traditional advice was to point it in the same direction as everyone else :)
    Though not everybody has one now, so it's not so easy.
    If it's on a pole, it is probably easy enough to rotate if it's not perfect.
