New aerial for freeview?
Discussion in 'Freeview & YouView' started by happyh, Oct 12, 2004.
  1. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Just got a new Pan viera. I have sky , which is fine but as the tv has Freeview as standard I thought I might as well use it. My tv aerial is not up to the job. My local (trusty) fitter has quoted me to supply and install a Hi-gain aerial @ £150. I thought this was a bit steep.
    Any opinions?
    Thanks.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    TBH I don'tthink £150 is too bad. I've seen quotes a lot higher than that.
    Yes you could buy an aerial and cable yourself for around £50 or less, but do you fancy climbing on your roof to fix it in place and then running the new cable? Then if anything goes wrong its down to you, where as the 'fitter' will offer a guarentee should the roof star leaking etc.
    Mark.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
    If you are in a peripheral signal area, then a (possibly - depending on the transmitter) wideband, high gain aerial may well be required. I agree, it isn't a large sum, given
    a) that they have to bring ladders and climb to dizzy heights and to supply the aerial and cable and end points
    b) what you've spent on your equipment.
    On the other hand, if you are 20 miles, clear line of sight, from a major high-powered transmitter then any old aerial hung in the loft might suffice. If your contractor is a member of the trade association, he's probably offering you just what you need for reliable, glitch-free reception.
  4. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    That is not bad. I have just paid £250 for a new mast, high gain aerial, DAB aerial and FM to be fitted.
  5. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Thanks guys. I'll go with it.I didn't realise how tight I was!
    (Am in a poor reception area too)
