new Aconda 9381 HD/DR+¿pal progressive?
Discussion in 'General TV Discussions Forum' started by malaga, Oct 25, 2003.
  1. malaga
    malaga
    I am new in this Web and is very good.
    oh! sorry for my bad english :thumbsdow
    is known already something of these models?
    some characteristic?
    and on its tube of image?
    ¿the new cybertube slim of philips?:suicide:
    in Germany they speak of her in this web:
    http://www.loewe-homecinema.tv
    thank you very much to all from Marbella (in spain):hiya:
  2. malaga
    malaga
  3. fatbob
    fatbob
    May 22, 2003
    267
    19
    Malaga,
    The Aconda in the US is different to the one that's available in Europe.
    While the US version accepts progressive signals through it's component input, the European version will only accept progressive RGB through it's VGA input, which rules out the use of a progressive dvd player. A scaler or HTPC is always an option, but for most home theatres built around a tv, this is often inpractical.
    Bob.
  4. malaga
    malaga
    you talk about to 9381zw or new 9381zw hd (or HD/DR+) ????
    perhaps the new series aconda hd already brings entrance of components for pal progressive.
    it would be logical ¿or no? :nono:
    thanks:hiya:
  5. fatbob
    fatbob
    May 22, 2003
    267
    19
    Hi Malaga,
    The Aconda I'm refering to is the 9381, the version which has been available for a few years now.
    I'm not sure if the new Aconda's will feature progressive capable component inputs. The only info. I've read so far is that they will feature an inbuilt hard disk recorder, but I do think that it's doubtful that they will feature a progressive input (other than the optional vga input).
    Cheers.
  6. malaga
    malaga
    then as it is the best option right now?
    I talk about to be able to enjoy a progressive reproducer dvd.
    that panasonic pd30 is progressive pal and ntcs, but they give a little fear the commentaries me on her.:confused:
    exists somebody that enjoys this television without no problem?:confused:
    ciao:hiya:
  7. hannanp
    hannanp
    Its my understanding that the Loewe can accept component input via a component to scart leead, don't believe its progressive though. Have you been able to find out any information on the upgrade Loewe are applying to the aconda/articos? I believe it includes the Hard Drive but is that all?
  8. malaga
    malaga
    according to loewe Spain, the models with HD/DR+ will appear at the beginning of the 2004.
    aconda HD/DR+ 9381zw will cost 2990 euros. :eek:
