new A/V amp advice
Discussion in 'AV Receivers & Amplifiers' started by Akcron, Sep 8, 2004.
  1. Akcron
    Akcron
    Sep 8, 2004
    164
    +4
    Hi All :hiya:
    i have decided to upgrade my a/v amp and with up to £500 to spend, need some advice ..i would love it to be good with stereo music as well...
    my sys consists of
    mission 771s front
    mission 771s rear
    mission 77c centre
    mission ms8 sub
    THx AkkY :thumbsup:
  2. CosmicOne
    CosmicOne
    Take a look at the Yamaha RX-V750 & RX-V1400.
  3. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    The better one for stereo is the Marantz 7400 that can be had for under £500 in www.unbeatable.co.uk
    the yamaah's are good in stereo but not as good as the Marantz, they are better with H/c than the marantz though :)
  4. Akcron
    Akcron
    Sep 8, 2004
    164
    +4
    Thx For the advice will add to the list to listen to :>)
