Question New 60-65" TV - which one and stick with 1080p or go 4K?
ctrlz
I'm in the market for a new TV. Possibly not the best timing because with TV tech the way it is at the moment, I'm torn between sticking with a good quality 1080p or moving to 4K.
I'll be using it for movies, TV, PS4 and also as a giant PC monitor. I'm not bothered about 3D and sound quality isn't important as that will be handled separately. The OS / software isn't even that important as I use my PC as a media centre. So basically I'm just looking for the best panel I can get for about £1500.
I've been looking at the Sony KDL-65W855C, purely because I was looking at the KDL-55W805C last year and it looked like a great option, until I decided to go bigger. Am I assuming too much in thinking that the 855C will be of comparable quality?
Secondly, I see that there are some 4K TVs in the same sort of price range (maybe if I drop 5" or so from the size). For example the LG 60UF850V. So is it worth making the jump to 4K, or would I suffer from the limitations of cheaper 4K TVs (no HDR, poor upscaling, etc) and therefore be better off sticking with 1080p?
Any advice to help me finally reach a decision would be massively appreciated!
