Question New 50EX700B owner, questions
Discussion in 'Panasonic TVs Forum' started by jason85, Dec 30, 2017.
  1. jason85
    jason85
    Dec 30, 2006
    36
    Hi all,
    I have just bought the above Panasonic after taking a u turn on the lgsj800v
    Can’t none tell me what picture setting is the best to use for normal tv viewing ie free view channels as that will be 90% of my viewing, unless there is a free view HD alternative. 10% of the time I’ll be using Netflix.
    Do the picture modes change depending on the source? So if I’m on iPlayer watching the UHD content and use a cinema picture mode with adjustments, do they change when I’m watching iplay showering just HD?
    Finally I was trying to watch iPlayer UHD blue planet but after about 10 min it cuts off saying there is an issue with play back and check internet connection. I know my wireless speed is about 18mbps is that too slow? Will I be any better off changing it from 2.4ghz as I’m using 5ghz
    Also am I better off using an Ethernet connection?
