new 37pf9986
Discussion in 'LCD & LED LCD TVs Forum' started by killer10971, May 22, 2005.
Tags:
  1. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    just received my replacement panel and what a difference , i thought the picture was good on my old set
    i had i replaced as i had the pip problem of a blue screen
    the main difference is that i dont get any problems with movement across a complicated background (brickwalls , or roof tiles ) i have no shimmering or jagged vertical lines , its like the reaction time of the panel has been improved (it was good before)
    very odd and the firmware is 2.3 and im still using roughly the jimsman settings from my old setup but an inprovement against the old one
