new 360 need help!!!
killer10971
just got the blockbuster deal and bought dead or alive today , i noticed the 60hz sticker and thought no problems with my philips pf9986 37inch lcd (it does support 60hz i checked)
in the display settings for xbox i changed from pal 50 - 60hz and the screen goes blank then goes back to pal 50 as i cant accept the changes
the tv dosnt have component inputs just dvi,scart,composite and vga ,at present its connected via the supplied scart
is this an xbox fault or the tv not accepting 60hz via scart
cheers
A
Apothis
Sounds like the tv just not accepting the input. Get a vga lead, fix all your probs (well, 360 display related ones anyway) right there :)
killer10971
cheers for that
just plugged in my ps2 and tried a 60hz game in the same av port and it worked no problems
very odd im going to try to change to console i think
cheers
Alun
Cant you try it on a different TV first?
Or try it without the scart adapter
killer10971
changed the xbox for a new one and same problem :rolleyes: so i picked up the vga cable
my set came with vga to dvi converter used that and all works perfect , pain in the arse as my dvd is on the dvi so i will have to keep unplugging (not getting a switcher just yet)
would a proper xbox scart work or will it be the same as the composite cable with a scart adapter
thanks for the help , appreciate it
Alun
The Microsoft Scart Lead is RGB capable so you will see some improvement over the composite lead.
Why dont you use the 360 for dvd playback?
IIRC it upscales over VGA
DragonOfSilver
If you don't have component you WANT to be using the VGA, or you're missing out on all the lovely HDness of the 360.
you will want to plug it back into composite though and set it 60 hz, incase you get the odd old game that moans about 50hz stuff in vga if its not set.
also, be aware that for reasons best known to themselves, majority of pal xbox 1 games will not run on 360's emulator in VGA complaining about wanting 50hz.
killer10971
i will stick with the vga and just have to unplug as needed , the reason i dont want to use the 360 for dvd playback is i just bought arcam gear for dvd playback
cheers
