New 360 Advice
gra123
Looking for help with this guys, my boys 360 has got the 3 red lights and is out of warranty, as the broken one has a hard drive, is it possible to buy a new one without the hard drive as I think this would be the cheapest option for me.
Hillskill
Moderator/Games Reviewer
Yep, your exactly right. Buy an arcade, slap on your hard drive and away you go.
Are you sure MS won't fix your console ? The Warranty was extended to 3 years and even then if you lean on them they often cave. I would get a new one for your boy and then set about trying to get MS to replace/fix the old one. You would have nothing to lose.
King Tones
How old is the console ?
The 3 Red Rings fault is covered by a 3 year warranty :thumbsup:
Deftones
gra123
Thanks for the reply. I will try them again. The console was only repaired just over 1 year ago, but the guy on the phone said after the last repair they only cover them for 1 year.
King Tones
the console is three years and they replaced it just over a year ago with the same problem.
Ring them up and lean on them as Steve as said.
They should repair it seeing they have already done a repair that has only lasted a year. If no luck then pickup an Arcade and just add on the HD :thumbsup:
Deftones
gra123
Deftones
thanks mate:thumbsup:
Hillskill
Got them to fix it guys. As you said put a bit of pressure on them and they caved in. :clap::thumbsup:
Result ! Fantastic news mate. Only took you half hour aswell :smashin:
gra123
they said there had been a mistake with the console records, they even offered me a free gift, I took the wireless headset. Thanks again boys.
