New 32 LCD from Samsung 32S81B !!!!
Discussion in 'Samsung TVs Forum' started by nasser79, Apr 28, 2007.
Tags:
  1. nasser79
    nasser79
    Hi there,
    I was looking for a new 32 LCD, I checked the the following models:
    1-Sony Bravia 32 S series
    2-LG 32LB1R
    3-Sharp Aquos LC - 32AX5M
    4-Hitachi 32lD9000TA
    and I came with a shorter list ( Sony or Hotachi), then a guy told me about the new Samsung model 32-S81B (which is a successor to the 32-S71B ), I am a little bit confused now, becuase I don't really like Samsung but it seems to be really good LCD, I'm mostly interested in watching SD tv channels -since no HT tv in our region yet !- and connecting my PC to it and some gaming from time to time,
    I was trying to check some information about this new LCD but nothing was up there since it's a very new model, even the specs page on Samsung's website is still empty !!!. Anyway I went and I had a look on it in the Show room, it looked very good with SD TV and I asked them to connect to a PC - it was very nice with the correct mapping, and here's a list of this model's specs:-
    1- Contrast ratio : 7000 [Dynamic]
    2- Response time : 8 ms
    3- Brigtness: 500 nit
    4- SRS TruSurround XT
    5- HDMI : 2
    6- PIP : yes
    and the link on the Samsung website :-
    http://www.samsung.com/me/products/tv/lcdtv/la32s81b.asp?page=Features
    finally - I need your opinion about it, since I am very new to Samsung world, I mean is it a reliable brand? does it compete with the brands listed above ?
    thanks in advance
  2. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    Can be reliable if you buy the right set from them.
    If you can stretch to a Samsung 37" R88, then the LE37R88BD is superior.
    1-Contrast Ratio : 8000:1
    2-Response Time : 8ms
    3-Brightness: 550
    4-SRS TruSurround XT
    5-HDMI: 3
    6-PIP: Yes
  3. nasser79
    nasser79
    Thanks for the reply but I can't raise the budget anymore,
    please your opinion within the options that I've listed,
    thanks
