New 24 DVD's
Discussion in 'Movie Forum' started by TheBigApple, Dec 21, 2002.
  1. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Can anyone tell me if the boxed sets of 24 that are in the shops now contain the new uncut discs?
  2. PoochJD
    PoochJD
    Aug 28, 2000
    11,002
    Norwich
    +1,861
    Monkey,
    Nope, they don't. They will still contain the original versions of discs 5 and 6.
    As such, when you buy the set, you will need to contact 20th Century Fox, and find out what to do to swap your "faulty" discs for new ones.
    Pooch
  3. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Bummer:(
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Play are selling the re-released uncut versions.
  5. tjmckeown
    tjmckeown
    Any idea how to tell which one you have? I bought it from Play a while ago, just after they were out of stock for about a month, so I assume I have the uncut version?
    Anyone know exactly what was cut from the original???
  6. MIKE HAMMER
    MIKE HAMMER
    Just what was cut from the original release on disc 5 and 6 of 24?Was it language or visual? I hate movies that are censored.
    Mike
  7. t-force
    t-force
    May 2, 2001
    1,859
    Southampton, UK
    +150
    It wasn't a case of censorship here: as I recall, the UK broadcast version of 24 was slightly longer in a couple of episodes (due to BBC2 not having any adverts to take up extra time) than the US one. Fox mastered the DVDs from the US-aired version, and so people who had seen the TV version said "eh? where's this bit gone?". I think that the VHS version was actually uncut in this respect.
    On another note: I've just been given the R1 version of 24. Can anyone inform me whether or not this one has the cuts, has been reissued, or was fully released in the first place?
  8. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    I've read from several sources that the R1 version is the same as the U.S. broadcast version.
  9. PoochJD
    PoochJD
    Aug 28, 2000
    11,002
    Norwich
    +1,861
    Yep, the R1 release actually contains the shorter US broadcast versions, whereas the R2 version contains the slightly longer broadcast editions!
    The difference is only about 30-60 seconds, but it's still a difference! In this instance, the R2 version is the one to go for!
    Pooch
  10. BLS
    BLS
    The last 5 episodes of 24 are all around 90 seconds longer in the UK versions than the US. (Durations around 42:20 not 40:50)
    This was not done to remove adult content but to make space for more adverts in the US. Hence the footage deleted is presumably what the producers deemed less important.
    However, there is at least one important scene which is not present in the US version! (if someone tells me how you do spoilers on here I can let you know)
    I have both the original r2 and replacement disks 5 & 6 and you can tell the difference by looking at the code on the disk:
    There is a short code number ending in .5 for disk 5 or .6 for disk 6 (from memory it's something like F20248.5) and the replacement versions end in V2.5 & V2.6 e.g. F20248V2.5
    Maybe someone who has bought a box with the newer versions in it can tell us whether the code on the outside of the box reflects this?
    I hope this is of some use to people
