Neutrik cable NL4FC
Discussion in 'Cables & Switches' started by philmate, Aug 18, 2001.
  1. philmate
    philmate
    Nov 6, 2000
    216
    Southend-on-sea
    +4
    Some stupid **** (myself) decided to take apart the above mentioned..and yes you've guessed it did'nt jot down where the r/y/b cables came from their allocated numbers incl + or _ in the connector. If poss could some informed person please let me know the correct locations so I don't damage my amp or sub and I can give this **** a good kicking.<br />Thanks
    Philmate.<br />Phil.
  2. Jim Robson
    Jim Robson
    Jul 14, 2000
    245
    Originally from the wonderful Granite City, Aberde
    Send an e-mail to Bob Davies <br /> [email protected] <br />as he's the Technical Manager for Neutrik UK Ltd.
    Regards
    Jim <img src="biggrin.gif" border="0">
    [ 20-08-2001: Message edited by: Jim Robson ]</p>
  3. RichardA
    RichardA
    I'm guessing that the cable you have got is not made by Neutrik, as the part number you've given is actually for a cable mounted connector so I can't help with the colour codes, but the (provisional IEC specification) pin assignment for the Neutrik NL4FC "Speakon" plug is as follows;
    1- = Return<br />1+ = Signal<br />2- = unused<br />2+ = unused
    or, for a biamped system
    1- = LF Return<br />1+ = LF Signal<br />2- = HF Return<br />2+ = HF Signal
    If there is any chance that power is being passed through this connector do not connect it up - check with the supplier!<br />The pins are marked on the connector (hopefully), if not contact me by e-mail and I can fax or scan & E-mail the layout.
    Hope this helps!
    Richard
  4. philmate
    philmate
    Nov 6, 2000
    216
    Southend-on-sea
    +4
    Thanks for the advice guys, I am now waiting for a reply from Bob.
    Philmate.
  5. philmate
    philmate
    Nov 6, 2000
    216
    Southend-on-sea
    +4
    Anybody?
    Philmate.
