Networking with XP-Home
Discussion in 'Networking & NAS' started by sapper, Aug 24, 2004.
  1. sapper
    sapper
    Jul 20, 2000
    2,232
    Southgate, North London
    +141
    I am attempting to network two PC's using a router (Netgear WGR614 v4).
    Currently the Broadband Modem is connected to the router and then the two Pc's communicate to the internet quite happily.
    However I am unable to create a network between the twoPc's when I run the network wizard.
    Since then I have tried to network the two machines together using a cross-over cable but no success.
    Up on further reading, it seems that the only way I can get XP (just home edition??) to network is to have one PC with two network cards and to use a ICS. The ICS connects directly to the internet via one network port and the other goes to the router.
    Is this absolutly necessary, or can I network both PC's to share drives, printer etc with out needing additional network cards through the router
    If I can, how?!?!?!?!
    Any advice would be most welcome.
    Adrian
    Mesh AMD 1900+ ASUS Motherboard 512 Mb RAM
    NVIDIA GeForce3 Ti 200 (64 MB RAM)
    60 G Harddrive (MAXTOR 6L060J3)
    Panasonic DVD-RAM Burner
    Pioneer DVD-ROM DVD-500M
    BLueyonder !MB Broadband
    XP Home Edition
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    If you can't network the 2 PCs using a cross over cable then something is definately amiss. XP home or pro should make no difference, the only networking difference is IIS and the inability to connect to a domain in XP home.
    If i remember correctly, you should just tell the wizard that you link to the internet through a central gateway, or if that option doesn't come up, i seem to remember choosing no internet connection. Then it should set the PC up on the workgroup MSHOME. Run the wizard on both PCs and you really should be up and running from there....
    And even though you've told the wizard there is no internet connection, i find it always gets onto the net fine through my router.
  3. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    Have you disabled the firewall, or created access rules?
  4. sapper
    sapper
    Jul 20, 2000
    2,232
    +141
    I think I have solved the problem.
    I dont really know how I did it, but I re-ran network wizard after reading your post/reply; and selected a slightly different option. The other thing was I left the default name of the workgroup to msworkgroup or what ever it is.
    It may seem sad but I named by PC's after a couple of nice ales, and I wanted to call the work group after the brewery!! so Im not sure whether it was the network name or the new wizard. Anyway Ican now access and see the drives on the other machines. Now it is a case of learning how to set up the various sharing of files mapping of drives?? etc.
    Thanks for your help, and the other thread may assist in the next stages ie file sharing, printer sharing etc, but I could not be bothered @ midnight!
    Adrian
