Matt_C
My mum's internet network seems to be plagued with problems and I'm getting to the point that I'm at a loss of what to do. I'll try to keep it as simple as possible to explain;
We started with a single Netgear DG834GT. She has an ADSL line from Talk Talk. Everything was fine but there was next to no usable wifi upstairs (large house, thick walls), so Talk Talk supplied a DSL-2640R router, and I installed both routers (the DLink downstairs, connected to master socket, and the Netgear upstairs, connected to the DLink via ethernet), with the same SSID and password to create one large wifi network.
That worked fine for a while, then one day devices stopped connecting to the strongest wifi signal, instead insisted on trying to connect to the primary wifi access point (the DLink). I couldn't figure out why, so I changed the SSID's and passwords of both to create two individual networks (at this point the SSID's became "DLink" and "Netgear")
This worked fine for a while until one of her lodgers couldn't get on the internet one day, and stupidly pressed the reset button on both routers, then of course nothing worked.
So last week I spent 4 hours trying to set it all up again as it was, and found a host of problems. I got both routers working again, on separate SSID's (DLink and Netgear) and my Mac could connect to both, get internet from both, as could my iPhone. The problems arose that my mums laptop (a Dell laptop running Win7) would connect to the SSID, but it would say in the sys tray that there was no internet access. I tried different channels, rebooting routers, rebooting the laptop, deleting the known/previous networks on the laptop, manually adding, automatically finding, etc etc. For some reason, it was treating the SSID's as "2" - i.e. instead of showing it was connected to "DLink" it was showing as connected to "DLink 2", and "Netgear 2" instead of "Netgear" - no idea why...
Anyway, I left it with it working - there was usable internet being transmitted via wifi on both DLink and Netgear routers, connecting via ethernet to either router worked fine, and her laptop also connected to DLink (not "2") and worked. Until this morning when I get a text saying that "Netgear 2 is back and can't get internet. Also printer doesn't work" (the printer is a wifi enabled Kodak printer)
So I'm at a loss now what to do. I can't work out whether the problem is network or laptop related, and to be honest I've had enough of it now. I just want it to go back to being simple and just working, not having to go over there every week to try and reboot/reconfigure the entire thing. The annoying part is, she has paying lodgers, so she has to be able to provide working internet. But I'm getting to the point that I just want to get a pro in to strip it down and start again, because whilst I know a little bit, I'm far from a pro and I'm getting stumped...
At the risk of trying to explain the hardware config, here's how it's set up;
Downstairs : master BT socket, ADSL line goes to DLink router. Wifi turned on, SSID = SMC_DLink
Upstairs : ethernet cable running from DLink router to Netgear router (to pipe internet). Wifi turned on, SSID = SMC_Netgear
Both routers have same password, just for ease. Both are on same IP range (192.168.1.x), with DLink being primary as 1.1 and Netgear box being 1.2 (manually set in Netgear settings to be on IP 1.2 - Dlink box is issuing DHCP from 1.3 and up). There are a few hardwired cables from from DLink box; 1 to the control unit for solar panels on the roof, and another going to terminal points in upstairs rooms - one of the lodgers likes to use the hardwire to skype, and a previous had a hardwire for PS3 gaming.
One part of me wants to ditch the whole set up, get a single, strong-power wifi access point, like a Cisco Aironet (ideally one that does power over ethernet) that I can install somewhere that will provide a strong and equal signal to both the upstairs and downstairs, and simply use the DLink box as an ADSL point, pipe the internet signal to the wifi access point and leave it at that. But on the other hand, I don't want to have to go out and buy new, and probably expensive, hardware, to make it work - especially if I get a call/text a week or two later saying the internet is working again.....
Little help?
Little help?
