Networking problem with LM620T
Discussion in 'LCD & LED LCD TVs Forum' started by zzchess, Aug 1, 2012.
Tags:
  1. zzchess
    zzchess
    Apr 30, 2012
    2
    Hoping that someone might have some idea of a solution to my problem.
    I have a LM620T 3D TV. When streaming videos either wired or wirelessly I keep getting problems with the videos continually freezing for a second or less. The same was happening when I tried playing the files via a USB memory stick. However, I discovered that disconnecting the TV from the network allows the files to play perfectly from the memory stick so it seems that something to do with the network is causing the TV to stutter. I have tried a different router but the problem persists. I have tried Serviio as well as Plex but the problem is the same.
    Any ideas/suggestions gratefully received.
  2. beermunter
    beermunter
    Aug 13, 2012
    3
    I had the same issue
    http://www.avforums.com/forums/lg-f...t-led-tv-thread-part-2-a-21.html#post17448297
    in the end got a replacement which streamed a lot better but it also went straight back because the screen was constantly flashing with red, green and blue stripes. not a good experience with the 620T TBH, great design , terrible build quality (for me)
    ordered an higher spec'ed LG because I do love the LG interface, fingers crossed this one is issue free.
    One thing I would try is stream from a different PC / laptop, to see if you can rule out that the issue is not with your usual machine...
    see my post for other things to try, IMO opinion the issue is definitively with the TV, I have the LG BP620 blu ray player streaming beautifully in another room on the same network the 620T crumbled on
  3. Boyd
    Boyd
    Jul 4, 2012
    33
    I'm having problems streaming HD from iPlayer and You Tube and wonder if my set might be faulty. I've got an LG Blu-ray and WDTV Live server connected to the same network switch and both work perfectly. Do you think that I should return the TV?
