Networking help!
Discussion in 'Networking & NAS' started by 9761, Aug 19, 2005.
  1. 9761
    9761
    May 16, 2005
    499
    Just finished my HTPC and I would like to network it to my other computer so I can share my Internet to my HTPC.
    HTPC is running MCE2005 and my other computer is running XP Home.
    Currently Ive got both of them connected via Crossover cable and am able to send and recieve files via the network but I am unable to share internet. I have all the options on my main computer to share my internet but my HTPC cannot recieve the internet or I havnt set it up right.
    Can anyone share some light on this please?
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Have you enabled internet connection sharing on the machine with the modem?
  3. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    OK, like the guy above said you need to enable internet connection sharing,
    kinda complicated to explain how to do it, but here goes...
    Make sure that the pc connected to the internet has two network cards, connect one of them to the modem and the other one to the other pc, make sure the internet is fully working on the main pc...
    Now on this pc(one connected to internet) open up internet explorer
    Go to Tools>Internet Options>Connections>Setup
    Press next then select "Setup a home or small office network"
    Press Next then Finish
    Now the rest is pretty easy, just select the network card connecting you to the internet (your modem) then follow the instructions....
  4. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    Another easy option (presuming you have broadband) would be to buy an ADSL Modem Router/Switch. I have recomended loads of these to friends/clients and would be happy to tell you how to configure it by PM if you so require. This is obviously cheap/no name stuff, but I've had no problems with half a dozen of the blighters. You can also go for more brandname models such as Netgear or DLink.
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=48449
    approx £30 incl Vat & delivery
    This also means you don't have to worry about buying or configuring a software firewall (such as XP Internet Connection Firewall). Using a software firewall is strongly recommended if you use a PCI or USB ADSL modem. Finally this avoids having to have one computer on all the time.
    Rajiv
  5. 9761
    9761
    May 16, 2005
    499
    Thanks,
    Im abit tired up for cash atm for Router as Ive just payed alot to build my HTPC and still havnt even got the MCE2005 remote yet :p
    Well on "Network Connections screen under my broadband connection it says " Connected, Shared"
    When I go into the options the internet sharing is on, now how do I get to surf the internet on my HTPC?
  6. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Did you set the ip address of the other machine manually?
    Easist way to make it all work is set to slave machine to dhcp and then reboot with the "server" machine still running.
  7. 9761
    9761
    May 16, 2005
    499
    Yeah did the ip address manually, Gave my internet PC 192.168.0.1 and then my HTPC 192.168.0.2
  8. 9761
    9761
    May 16, 2005
    499
    Where can I set this to dhcp?
  9. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Just set the lan adapter to get an ip automatically and dns automatically OR leave it as you are and add your isp's dns servers in the dns boxes of the slave computer.
  10. 9761
    9761
    May 16, 2005
    499
    Sorry to sound n00bish but how do I turn the IP address on automatically?
    In the options where I put it in manually it says automatically but it searches for ip address then when it has found a private address I get no connectivity. Ive tried with my other pc to and I still get no connectivity.
  11. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    You're in the right place just leave the ip as 192.168.0.2
    Set the first dns to 192.168.0.1 and the second to 4.2.2.2 and see if that works?
    LMK
  12. 9761
    9761
    May 16, 2005
    499
    Ok ive done that and my network is now connected but still no internet
  13. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Ok, on the "server" go to the internet connection/properties/advanced and in the internet connection sharing box, make sure you have all the options ticked.
    Are you on dialup or broadband, which isp?
  14. Rambles
    Rambles
    Jul 14, 2004
    7,695
    UK
    +902
    I had the exact same set up working ok for a year, it was a bit flaky to start with. Do you have a USB ADSL modem?
    It may be as simple as rebooting both pc's.
    If that doesn't work, cancel all the sharing and start again using the ICS wizard on both machines and leave all the IP address stuff to automatic.
    Then open up IE on the HTPC machine, and type in a web address and see if it loads.
    Hope that helps - that is the extent of my knowledge on ICS, so if still having problems one of the networking guru's on here will help you out I reckon.
  15. 9761
    9761
    May 16, 2005
    499
    Broadband with wanadoo 1Meg
    Ive clicked on all the boxes.
  16. 9761
    9761
    May 16, 2005
    499
    Yes its a rubbish Copperjet 800 USB Modem :(
  17. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,368
    63
    Andover
    +148
    The DNS on the HTPC should mshome.net - this will enable it to resolve IP addresses of websites. On the HTPC and XP get into a command prompt (not sure on MCE, but on XP goto start, run, then type in "cmd" without the quotes, in the black box that appears type in "ipconfig /all" without the quotes) and run ipconfig /all and post your settings for each machine.
  18. 9761
    9761
    May 16, 2005
    499
    MCE Command promt
    [​IMG]
    And XP Home Command promt
    [​IMG]
  19. rhinoman
    rhinoman
    Oct 31, 2000
    2,581
    71
    Herne Bay, Kent
    +33
    Are you running a firewall other than xp's?
  20. The Dude
    The Dude
    May 21, 2004
    6,163
    Beverley, East Yorkshire
    +2,447
    I'm not too familiar with the ins and outs of ICS.... but certainly the lack of a configured gateway on PC2 looks a bit odd?
    I'd try setting the gateway to 192.168.0.1 and then try pinging www.google.com
    what response do you get back?
    destination host unreachable ?
    timeout?
    something else?
  21. 9761
    9761
    May 16, 2005
    499
    I have no firewall as of yet.
  22. The Dude
    The Dude
    May 21, 2004
    6,163
    +2,447
    If you set your IP manually it's worth giving the gateway a try... sounds to me like your HTPC doesn't the way to get out...
  23. 9761
    9761
    May 16, 2005
    499
    Thanks its working now, all I did was type 192.168.0.1 into the gateway box and its working.
    Thanks to everyone who helped me through this matter.
    Thanks! :clap: :thumbsup:
