Networked HiFi
Discussion in 'Hi-Fi Stereo Systems & Separates' started by TurquoiseShark, Sep 11, 2007.
  1. TurquoiseShark
    TurquoiseShark
    I'm looking for a system which will stream music from my PC via network (the network is ran off Homeplug). I have used a 360 previously, but would like something more dedicated. Not bothered about speakers as I will put it through my amp. Price around 300-500.
    Any recommendations?
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Squeezebox is the obvious canadidate.
    The Sonos system is another much talked about system.
    Google will tell you all the technical info you need...
  3. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,not had a Squeezebox long,but finding it excellent.Analogue wise supposedly as good as a reasonable priced CD Player.Modded SB or the bigger brother Transporter,better but £1000.Don't matter to me as much,as i'm using the digital out to a CA840C.
    Look at Slimdevices website,even thou its now badged as Logitech.Theres a code that might get you it a bit cheaper(£176)from Logitech.
    Cheers BOB
  4. TurquoiseShark
    TurquoiseShark
    cheers!
    looks like the squeezebox then, but I'm reading of compatibility issues with Vista, which may cause me some problems (or should that be "add to my problems")
  5. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Drat double posted,Grrrrr
  6. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
    Hi,even the originator/designer + staff(prob payed by Logitech?)frequent the forum.
    You can run the main program,Slimserver on a NAS(Linux based i think).NAS's with it on already or whatever can be expensive thou.Theres cheaper solutions with a NAS,but these look a bit more complicated(to me at least,no programmer)& require a bit of work,getting Slimserver installed etc.Should maybe save a bit on electricity thou,if nothing else?
    Cheers BOB
