luckybib
I hope you might be prepared to give me some free advice?
I have successfully installed a pan/tilt i.p. camera outside my house, but now I want to record it. Currently only viewable on iphone
Apparently, you can view it on pc browser as well. I don't use this option.
The brand is an unknown bought from e bay (sorry!!!!)
I believe I need an nvr?
Or: maybe I connect a dedicated hard drive to the pc but I think I'm out of my depth setting this up.
I prefer as simple as possible, plug & play
I do have a stand alone pc not being used, maybe I hook this up?
Analytics would be useful to prevent trawling through etc I think I prefer nvr
There seems to be a minefield of loads of different version products, and I simply don't know what I'm looking for.
Is there a unit I can directly plug the end of the CAT5 cable into a recorder? most seem to want round old analogue style inputs?
The camera cable currently plus into the router.
Ideally I need as small a unit as possible, bit limited on space but if it has to be old-style dvd recorder size then ok.
I haven't got a rack to put it in.
any advice welcomed, if you recommend an easy plug /play product please give a link
