Jazz Monkey Jr
I have bought a network storage device but it seems slow transferring files. I am using the PC wireless as I have used the ethernet port for the storage device, I am using a orange livebox so I only have 2 ports, one is for the xbox 360. Would a network switch make it faster so I can connect my PC through the ethernet. The pc is very close to the router and I am getting 54mbps connection.
It is not gigabit connection on the PC.
If a switch is needed can you recommend a cheap one, thanks.
