so - you cleared everything, connected and it worked. Then you disconnected, moved it and it won't now connect. That's what happened to many others - although this generally is a wifi related complaint (not an ethernet connected one)Thank you. After I got my rant out of the way, did two more factory resets of the Node. Re-deleted the Bluesound app. Re-installed. First attempt at connecting to the Node showed as connected but I still could not finish the setup. Tried two more times and finally got the setup finished. It worked. Played a couple of songs. I had the Node in a temp setup while I was messing with it. Unplugged it, move it to the permanent location, plugged everything back in, and it is back to there I started -- it is not connected and and will not connect.
Again, I would like to thank everyone for their assistance but I am done with the Node.
Can you connect it again and work out the mac address on the node? I'm guessing that one of the 3 unnamed entries in the dhcp client table you showed is the Node 2i.
The node won't have a default ip address - but you can give it one which may stop it getting confused.
