Bogdar
Hi!
I recently purchased Dali Opticon 6 (4ohm, 89dB) and want to replace my Denon AVR-S650H.
All I need is:
My budget is $2k (may rise a bit if there will be really sweet options). I don't like Yamaha due to nature of sound with my speakers (tried with r-n803 and some of their AVR at the shop) and also app is not convenient for me, so WXC-50 is not an option. Here is what I can afford from budget and availability in my country perspectives:
I doubt if NAD C368 is an amp that will properly control my speakers while C275-based combos will probably have poor DAC/Preamp sections but allow upgrades with extra DAC and/or pre-amplifier later.
My music is 90% rock and heavy, from Queen to Metallica etc., not so loud, from 57dBa at night to 75-77 dBa SPL at noon, so ability to sound well on low volume is important.
So my questions are: if NAD C368 can give me the best of my speaker? Are that Blusound and Heos streamers audible bad?
If there much better streaming preamp around $1k with trigger output to couple with power amp please let me know too, I will check if it is available at shop or for ordering online.
My priority are management of playlists, volume and power from the single app, I hope it is possible around $2k in total.
Thank you.
All I need is:
- playback from NAS (Flac now, probably DSD later)
- Toslink or HDMI ARC for Smart TV
- Airplay.
- Probably Spotify connect.
- NAD C275BEE as power AMP with Denon Heos HS2 or Bluesound Node 2i as streamer/dac/preamp. Both have trigger out, so I can control the amp and volume from the application.
- NAD C368 as power amp / pre-amp / DAC + BluOS MDC as streamer - it is single box that sould be upgraded with HDMI module for handy integration with TV (ARC and power/volume control from TV remote)
Thank you.
