Thebadbandit
Can you help with the following ?
I have had this problem before but cant remember the correct way.
I have a pc conected in oe room through ethernet and another im trying to connect wireless from another room.
It has worked with no problemS for months, it is only after a complete reinstall of the pc which is wireless that as meant I need to know the wep key.
When generating the key through zyxel config page the key is always 2 digits long.
Have you any ideas ?
