mcav
[IMPORTANT ADDITION TO POST]
If you have come to this thread because your Panasonic Viera Firefox OS Smart TV is not connecting, and delivering services like Netflix, Youtube, Amazon etc... then it is very likely nothing to do with your home network, internet connection, nor your TV.
Panasonic route all app based traffic through their own cloud servers. The official reason is to 'ensure a consistent experience'. The real reason is so they can mine user data.
The problem is that when the cloud servers fail (and they do), your access to the content, including paid content is blocked entirely, with your TV telling you to check your connection, your TV confirming that the connection is fine, and round and round you go.
Do not factory restore your TV if you are experiencing issues as described above. Instead make your complaints known to Panasonic. You can find Panasonic on Facebook and Twitter, and of course you can call them. The specific details will depend on your location.
In the UK it is @PanaService_UK for twitter and you can find Panasonic UK on FB here Panasonic UK
You can also call 0344 844 3899 in the UK.
In the mean time, the servers that are going down are as follows (including aliases)
https://mhc-xpana-eu.myhomescreen.tv / 81.93.189.220
https://mhc-ajax-eu.myhomescreen.tv
https://mhc-sec-eu.myhomescreen.tv
Please do go through the whole thread to get a full idea of the extent of the problem. I have put this at the top of the thread to make sure people don't need to go through pages of info to figure out what is likely wrong with their TV.
S.
[ORIGINAL POST]
Hi all,
I seem to have encountered a problem with this TV. It is connected via a wired connection (though changing to wireless does not seem to fix this issue). The router has been tested to work just fine, it connects to different devices without issue, both wired and wireless. Checking the Network Status on the TV, it is reporting happily that it is connected to the router and after that, the internet.
The problem is that none of my apps are launching. At all. If I go in through the home button, then to apps, then select an app (say, Netflix), there is literally no response, followed by "Network error occurred". If I select OK it puts me back to where I was. I can go in through "Apps" and select an and (say, Youtube), and I get more of the same, then I get "This App will be available soon".
I have just reset it to "out-of-the-box" settings, losing all my colour adjustments into the bargain, to find that it has not helped at all.
Other apps keep telling me that I need a network connection, bouncing me to the network set up pages. I just tried to launch BBC iPlayer to be given a network error (E3502).
Interestingly, I can get into some apps by way of the freetime and FreeviewPlay apps - for example, BBC iPlayer works that way.
Having got that to work, I have returned to trying Netflix and one again I have got nothing.
I'm now going round in circles and getting nowhere. Does anyone have any help they can offer?
Thanks in advance.
S.
[ORIGINAL POST]
Hi all,
Thanks in advance.
