network help
Discussion in 'Desktop & Laptop Computers Forum' started by scouse, Oct 18, 2004.
  1. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    Hello everybody...
    I need to connect 3 xp pc's and a mac to a wired adsl router. Are there any problems with connecting the mac to an ordinary adsl router?
    Could you please recommend a suitable router for my purposes.
    Cheers :thumbsup:
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Most routers will deal with mac computers absolutely fine but a few dont. In my experience Netgear make great firewalls and routers. I will recommend the DG834 (I have the same model but the wireless version) as it is very secure - have never had a single intrusion through it and the remote facilities can be configured very easily.
    http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=52754 is a good place to get it and it isnt that expensive...
    Alternatively there is the basic Ebuyer version you can try but it requires much more out of the box configuration and is probably a little less secure/reliable.
    Chris
  3. scouse
    scouse
    Jan 22, 2003
    285
    Balham
    +3
    cheers fella that looks perfect for my needs
    thanks muchly :smashin: :D
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,494
    South Derbyshire
    +203
    I can recommend the DG834 as well.
